Vedro2081 Posted March 11, 2014 Report Share Posted March 11, 2014 I had a Fiberglass pool installed last summer and shortly after the contractor was done with the work i realized that if i the spa is overflowing into the pool and i switch it back to only the pool my water level in the spa drops below the water level in the pool. It doesn't look like the water goes back to the pool as the water level is not going up. Weird thing is that if the pump is running and the spa is overflowing into the pool, the overall water level is not dropping. Can someone help with this? The contractor ran out of business shortly after i realized the problem. Quote Link to comment Share on other sites More sharing options...
soriano Posted April 1, 2014 Report Share Posted April 1, 2014 Hi do you happen to have jandy 3 way valves install in your system? If you do this could be the the part that the contractor didn't set right. Quote Link to comment Share on other sites More sharing options...
