hamburger Posted October 21, 2005 Report Share Posted October 21, 2005 I'm selling my house and Emerald hot tub stays there. My question is, can I pull the ozone from the 8 year old hot tub and install it on my new purchase, if it doesn't have one already? If so, how do I cap off the ozone jet in the tub?? Thanks again in advance. Quote Link to comment Share on other sites More sharing options...
spatech (the unreal one) Posted October 21, 2005 Report Share Posted October 21, 2005 I'm selling my house and Emerald hot tub stays there. My question is, can I pull the ozone from the 8 year old hot tub and install it on my new purchase, if it doesn't have one already? If so, how do I cap off the ozone jet in the tub?? Thanks again in advance. That's probably an old UV type and I'd be surprised if it's even doing anything for you anymore. Quote Link to comment Share on other sites More sharing options...
kcspaguy Posted October 21, 2005 Report Share Posted October 21, 2005 I'm selling my house and Emerald hot tub stays there. My question is, can I pull the ozone from the 8 year old hot tub and install it on my new purchase, if it doesn't have one already? If so, how do I cap off the ozone jet in the tub?? Thanks again in advance. You should be able to just remove the screws retaining the unit to the cabinet, then remove the end of the hose where it attaches to the the plumbing. You may need to twist this as you pull it off. It is just a friction fit over what is known as a "nipple" or "barbed fitting". Before removing the hose, you will want to go to your local hardware or auto parts store and get a "vacuum cap" of the proper size and a small tube of silicone sealer. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Spa-Guy Posted October 22, 2005 Report Share Posted October 22, 2005 That's probably an old UV type and I'd be surprised if it's even doing anything for you anymore. Spatech is right. An 8 year old ozonator is 99% likely to be a U.V. Ozonator. The chances, that it is still operating are slim and none. A long life would be 5 Years for a U.V. Bulb. A Bulb is a bulb, they go bad. Most U.V. Ozonators will put out a noticeable blue glow, to indicate it is operating. If the low speed pump or filtration cycle is on, then so should the ozonator, with a blue glow. No glow, no go. Ozonators can be purchased very reasonable these days and are simple to install, on todays ozone ready tubs. Goodluck Dave. Quote Link to comment Share on other sites More sharing options...
Chas Posted October 22, 2005 Report Share Posted October 22, 2005 Quote Link to comment Share on other sites More sharing options...
Spa-Guy Posted October 23, 2005 Report Share Posted October 23, 2005 Chas, Even when you don't speak, you say the right thing. Dave. Quote Link to comment Share on other sites More sharing options...
hamburger Posted October 23, 2005 Author Report Share Posted October 23, 2005 Yeah, you guys are right. It's a UV and no blue color coming from tube at all. I'll leave it there and have a new one installed on my new purchase. Thanks again. Quote Link to comment Share on other sites More sharing options...
Spa-Guy Posted October 23, 2005 Report Share Posted October 23, 2005 Good Choice. Let us know if you have any questions installing an ozonator on your new spa. Dave. Quote Link to comment Share on other sites More sharing options...
