Orion6192 Posted October 6, 2012 Report Share Posted October 6, 2012 Just curious... First night with our tub and I have one of the air toggle switches on our Jacuzzi J345 that whistles on pump1 on high and gurgles with pump 1 on low. This would be the toggle switch on the left side of the water fall if your facing it. That would be with the Jacuzzi logo out which would mean the air is on and it's sucking air though the switch? If I turn the massage selector switch which is to the right of the waterfall on the corner so it points to the middle or back of the tub is when it makes noise. If I turn it to the front it diverts the air I think because then it doesn't work at all. If you splash it or water gets up on it, it will suck the water in. The plastic cover on the outside of it pop off and there is a flat rubber washer under it. Everything seems okay... Anyone else have this issue? Quote Link to comment Share on other sites More sharing options...
Orion6192 Posted October 8, 2012 Author Report Share Posted October 8, 2012 If I put a piece of Reynolds wrap over it, it vacuums down flat so it is sucking in air... The others seems to do the same, just not as aggressively. Anyone else confirm if they have ever seen this or heard of it? Thanks... Quote Link to comment Share on other sites More sharing options...
