BeachBoy Posted May 8, 2012 Report Share Posted May 8, 2012 Some background: have previous experience with 24' round above-ground pool, bought foreclosed home, and obtained my first in-ground pool. The in-ground pool is 18' x 36' in size, 3' to 8' in depth, and step entrance. The filter pressure runs about 10 psi. If I remember correctly, the psi was about 40 psi on my previous above-ground pool. My in-ground did have a bottom drain but a previous owner had in removed. Now the pool has one skimmer. My question is: what is your pool pump pressure and what is your pool size? Quote Link to comment Share on other sites More sharing options...
pulleyman123 Posted May 8, 2012 Report Share Posted May 8, 2012 The pressure depends on alot of factors. If you start with a clean filter, that is what your pressure should be at. The pressure will be different from system to system based upon the plumbing sizes, amount of head, etc. If your filter is clean, that is where your pressure should be at. Quote Link to comment Share on other sites More sharing options...
yanks1 Posted June 4, 2012 Report Share Posted June 4, 2012 Beachboy... I'm usually in same range (8-10 PSI) with in-ground pool with 25k gallons. We have an Anthony DE Filter (52 sq ft)& 1.5 HP pump. Enjoy the pool and good luck Quote Link to comment Share on other sites More sharing options...
Delgado Posted June 10, 2012 Report Share Posted June 10, 2012 Mine is at 10 psi as well , sta rite system , but when I run the in floor system it rises to 20 psi Quote Link to comment Share on other sites More sharing options...
rlott Posted June 12, 2012 Report Share Posted June 12, 2012 I get 10 psi with a clean filter and 20 with a dirty filter. 2" piping with a Jandy Stealth pump. Quote Link to comment Share on other sites More sharing options...
