decadude Posted April 13, 2012 Report Share Posted April 13, 2012 I had a pool guy come out and he indicated to me I had a bad control board and showed where water had gotten in and damaged the board. The warranty company indicated that they would cover the troubleshooting but not the board replacing. (just bought a new house this is a home warranty) So I buy the board online and plug it in and nothing the board does not even give a display. If I remember correctly the display on the other board worked fine, but i do know computers and the guy showed me the yellow discoloration of the board. The spas Heater Display Cover was removed at one point and time and this is the reason for the water damage. I read online about how the only replacement board will work with a stack flue sensor rather than a stack flue switch. I am not able to locate whether I have a stack flue sensor or switch and I have no clue if this pool guy is right. He stated he used to work for starite so I am assuming he knows the equipment. I had another pool repair guy say i was a board of some sort inside this box. He came out prior to the other guy on another matter I was having with my pools backwash line. So he spent a little time on the spa heater. I am 10 kinds of confused on this and hope I can figure something out here. thanks to all who reply Quote Link to comment Share on other sites More sharing options...
decadude Posted April 13, 2012 Author Report Share Posted April 13, 2012 im 100% new to this I get an error code 6 now i think I was forgetting to turn the filter pump on when putting in spa mode so now i know filter pump first hopefully nothing is messed up I am trying to now determine what error code 6 means Quote Link to comment Share on other sites More sharing options...
decadude Posted April 13, 2012 Author Report Share Posted April 13, 2012 I found my manual E06 errors mean the issue is related to fuel supply, thermal regulator, check for correct orifices. Not sure how to check if gas is on Quote Link to comment Share on other sites More sharing options...
decadude Posted April 13, 2012 Author Report Share Posted April 13, 2012 I noticed when the heater comes on it reads 126 degrees then kicks over to E06 could this be the thermistor. Also I am curious if this is the thermal regulator I am assuming so but im pretty new to all this and learning. I am still not sure how to check if I have a stack flue switch or stack flue sensor. Quote Link to comment Share on other sites More sharing options...
decadude Posted April 13, 2012 Author Report Share Posted April 13, 2012 Ok, I have an update I got the board working had to program the board to the unit by pressing down the bottom far right button and holding then letting go hitting the buttom again after this i had to use up down arrows to program my unit i had pentair walk me through the steps on programming the control board to my unit i was able to determine i have a stack flue sensor seeing that the board works with my sr333na heater furthermore troulbleshooting i have been able to determine I believe my igniter is not working properly after testing the male connectors on the igniter with ohm meter they give no read should read between 40-70 ohms Quote Link to comment Share on other sites More sharing options...
