ryan3148 Posted March 14, 2012 Report Share Posted March 14, 2012 i recently got a used 1999 tiger river spa hot tub and i tried to fill it up to see if it was working but it leaked. i see there is a 3/8 tubing that was cut under the hot tub on one side and another 3/8 tubing attached to nothing and when i filled it thats where all the water started to come out how can i fix this. thanks Quote Link to comment Share on other sites More sharing options...
Spanky Posted March 16, 2012 Report Share Posted March 16, 2012 It may be an Ozone line.... Does one end attach to a jet? (Ozone injector) If I'm right, then you will have to make a "Hartford loop" and attach a check vave to the open end to stop the water from backing through the tube Quote Link to comment Share on other sites More sharing options...
