op1 Posted November 29, 2011 Report Share Posted November 29, 2011 Anyone here familiar with the Sundance Select-A-Sage jets. According to what I've read the jets are suppose to be interchangeable. I should be able to put in one of the Sunstorm spinning jet and take out the stationary nozzle. But the jet housing has a rather large estuchen which does not appear to be removable. I don't want to try to force it. If anyone is familiar with these jets I could use some guidance. I really like the spinning jets and am considering purchasing some more. OP1 Quote Link to comment Share on other sites More sharing options...
david_bilton Posted November 29, 2011 Report Share Posted November 29, 2011 Anyone here familiar with the Sundance Select-A-Sage jets. According to what I've read the jets are suppose to be interchangeable. I should be able to put in one of the Sunstorm spinning jet and take out the stationary nozzle. But the jet housing has a rather large estuchen which does not appear to be removable. I don't want to try to force it. If anyone is familiar with these jets I could use some guidance. I really like the spinning jets and am considering purchasing some more. OP1 no I just did one of these jets and could not find anything to fit in the hole and get one soon as they are hard to get and sundance took a month toget it to me. good luck Quote Link to comment Share on other sites More sharing options...
op1 Posted November 30, 2011 Author Report Share Posted November 30, 2011 no I just did one of these jets and could not find anything to fit in the hole and get one soon as they are hard to get and sundance took a month toget it to me. good luck Thanks for your reply. The Jets are available on line through a couple of different vendors. If you google Select-A-Sage or Sunstorm you'll find the parts along with some pretty detailed parts drawing. That's how I found out the spinning part is suppose to be interchangeable. The only thing I am not sure of is how to remove the estuchen that doesn't have the center piece to hold the spinner in. They seem pretty firm in there and I don't want to force it. OP1 Quote Link to comment Share on other sites More sharing options...
op1 Posted December 5, 2011 Author Report Share Posted December 5, 2011 Bump Anyone else with any experience with these jets and changing the escutcheons? OP1 Quote Link to comment Share on other sites More sharing options...
JAMES THE HOT TUB GUY Posted December 9, 2011 Report Share Posted December 9, 2011 Bump Anyone else with any experience with these jets and changing the escutcheons? OP1 I can help with your issues send me an email and i will reply with my nuber and you can call me premierhottubs@etcmail.com Quote Link to comment Share on other sites More sharing options...
op1 Posted December 14, 2011 Author Report Share Posted December 14, 2011 Bump Anyone else with any experience with these jets and changing the escutcheons? OP1 I can help with your issues send me an email and i will reply with my nuber and you can call me premierhottubs@etcmail.com James, It worked!!! Came right off. Thanks you really know your Sundance!!! OP1 Quote Link to comment Share on other sites More sharing options...
