TideJoe Posted November 21, 2010 Report Share Posted November 21, 2010 I've read how to remove the old one and install (pulling the wire through the conduit) the new one, but what kind of sealant/adhesive do you use when you put the new one in? Thanks Quote Link to comment Share on other sites More sharing options...
Spa God Posted November 21, 2010 Report Share Posted November 21, 2010 silicone, but use a good one a clear bathroom tub high end one will do. run a bead in the groove on the underside of the panel and away you go... Quote Link to comment Share on other sites More sharing options...
TideJoe Posted November 21, 2010 Author Report Share Posted November 21, 2010 silicone, but use a good one a clear bathroom tub high end one will do. run a bead in the groove on the underside of the panel and away you go... gracias Quote Link to comment Share on other sites More sharing options...
grandee1 Posted November 22, 2010 Report Share Posted November 22, 2010 When I replaced mine I used a Marine Grade silicone. Much better than anything used in the bathroom. It will also stand up to chemicals much better. Quote Link to comment Share on other sites More sharing options...
Spa God Posted November 22, 2010 Report Share Posted November 22, 2010 Is there really any difference from the top end indoor outdoor anti bacterial silicone to the marine grade with the exception of the label and price? Quote Link to comment Share on other sites More sharing options...
tampagrl70 Posted November 22, 2010 Report Share Posted November 22, 2010 as a tech for several yrs I would definitely go with the marine sealant,, cheaping out will give you voids and in turn leaks that can ruin everything Quote Link to comment Share on other sites More sharing options...
Spa God Posted November 23, 2010 Report Share Posted November 23, 2010 Ive always used the GE Silicone II Sealant... hell it works in the bathroom and that is much harsher than a Hot Tub environment, heck look around the shower... It's wet almost all the time, gets subject to harsh chemicals weekly in a way higher concentration than your hot tub ever would and lasts 10 years, and still looks fine!!! I am 99% certain that marking the stuff "marine grade" is a marketing ploy designed to fool us into paying 3X the price for the same product. The biggest difference with the marine grade seems to be the fact that it does not have acetic acid in it which only matters if it is used on metal... no real benefit in a hot tub, in fact some Marine grades are silicone mixed with other sealants and are often polysulfide-based which can adversely affect plastics. Never had issues with silicone failure... frankly the surface prep and application is probably way more important than the actual sealant! Quote Link to comment Share on other sites More sharing options...
