gypsy Posted October 31, 2010 Report Share Posted October 31, 2010 A family friend recently gave us a Jacuzzi Hot tub. (225 gal.) It is up and working, but now we need to get the water quality right. What is the best way to learn about water chemistry? We tested the water quality with the strips and our Bromine was low, and our pH and Alkalinity levels were high. Our friend gave us a box of chemicals, but we do not want to start putting them in unless we know what they will do to the water. Quote Link to comment Share on other sites More sharing options...
footie Posted November 1, 2010 Report Share Posted November 1, 2010 I found out that with Bromine you do run higher than usual pH levels, mine has a reading of between 7.9-8.0 which is actually OK with Bromine, my Alkalinity is the opposite to yours, I am low at 80 but it seems to work for me, I think as long as the two readings are stable you are fine. Hopefully some of the expert should pipe in soon with more detailed advice. Quote Link to comment Share on other sites More sharing options...
Razorhog Posted November 1, 2010 Report Share Posted November 1, 2010 I don't do bromine, but check out this thread: http://www.poolspaforum.com/forum/index.php?showtopic=26324 Quote Link to comment Share on other sites More sharing options...
gypsy Posted November 1, 2010 Author Report Share Posted November 1, 2010 Thanks for the replies. I added some acid, now my levels test within range. My only means of testing are strips. Today I went to the local spa store to buy a test kit and all they sell are strips. So when I came home I ordered a Taylor k-2106 online. Should have it by Thursday. I'll post more when I get the proper test results. Thanks again, Gypsy Quote Link to comment Share on other sites More sharing options...
gypsy Posted November 30, 2010 Author Report Share Posted November 30, 2010 Sorry it's taken so long to get back, I had a delay in the arrival of the test kit combined with learning how to use it. Following the advise on the link to Water Bear's recommendations, I've been able to keep my total alkalinity right around 100 ppm; my pH has been around 7.4 - 7.6; and my bromine level around a 5 or a 6. I add 2 oz. of Clorox every time I use the tub, and the levels have been pretty consistent. My pH creeps up and if I add around a 1/4 oz. of muriatic acid it brings it right back to ideal. After adjusting the pH 3 or 4 times, I have to add an oz. of baking soda to bring my TA back to 100 ppm. My concern is my calcium hardness is only 150 ppm right out of the tap. I have well water and my only means of treatment are a particle filter and a charcoal filter. Do I need to raise my calcium hardness, and if so, how should I go about it? I do get some foaming when I use the jets on high. Will raising my calcium hardness help this also? Thanks for your help, I would have never made it this far without this forum! Gypsy Quote Link to comment Share on other sites More sharing options...
PaulR Posted December 1, 2010 Report Share Posted December 1, 2010 Calcium hardness at 150 should be fine. Does the "foaming" go away pretty quickly after you turn the jets off? If so, I wouldn't worry about it. Regarding TA, your tub might prefer TA 80. See whether the pH is more stable at TA 80; if not, then your current routine sounds reasonable. Another option to stabilize pH is to add 50ppm borates. I do that, and it takes months for the pH to move up enough to need correcting. --paulr Quote Link to comment Share on other sites More sharing options...
gypsy Posted December 1, 2010 Author Report Share Posted December 1, 2010 Thanks, the foaming goes away as soon as the jets are turned off. Water returns to clear pretty quickly also. I wouldn't call it sparkling, but if you take a glass full and hold it up to the light it appears to be clear. gypsy Quote Link to comment Share on other sites More sharing options...
