vanderic74 Posted August 20, 2009 Report Share Posted August 20, 2009 Hi I just bought a house that came with a Hot Tub. I am a novice, and as a novice I went to a spa specialist called Club Piscine in Montreal. They recommanded me to do a thorough cleaning of the hot tub (pipes, whole system) with the CLR product. http://www.jelmar.com/CLRbasic.htm It seems to be a very agressive way to clean my hot tub. Should I trust them and do it? Is it ok? Anyone did it? Thanks Eric Quote Link to comment Share on other sites More sharing options...
ps558 Posted August 20, 2009 Report Share Posted August 20, 2009 Hi I just bought a house that came with a Hot Tub. I am a novice, and as a novice I went to a spa specialist called Club Piscine in Montreal. They recommanded me to do a thorough cleaning of the hot tub (pipes, whole system) with the CLR product. http://www.jelmar.com/CLRbasic.htm It seems to be a very agressive way to clean my hot tub. Should I trust them and do it? Is it ok? Anyone did it? Thanks Eric I wouldn't use CLR. Look for Natural Chemistry Spa Purge. It pull all the crap out of the plumbing lines alot better than just shocking. Swirl Away is another one Quote Link to comment Share on other sites More sharing options...
vanderic74 Posted August 21, 2009 Author Report Share Posted August 21, 2009 I wouldn't use CLR. Look for Natural Chemistry Spa Purge. It pull all the crap out of the plumbing lines alot better than just shocking. Swirl Away is another one I would have liked to use your advice, but I already bought 2 bottles of CLR Do you think it would actually damage the spa, pipes, system or any part of the spa? Even though you recommend other products, is CLR still ok? Thanks Quote Link to comment Share on other sites More sharing options...
PaulR Posted August 22, 2009 Report Share Posted August 22, 2009 Use the CLR only if you have a calcium buildup for it to attack. Put it on the shelf otherwise. Instead I suggest you look at this Spa Decontamination procedure. --paulr Quote Link to comment Share on other sites More sharing options...
