PaulR Posted August 1, 2009 Report Share Posted August 1, 2009 If you have some distilled water you can dilute the pool water 50-50 with the distilled, test that mixture, then double the reading. Or you can get a FAS-DPD test separately from Taylor, or from tftestkits.net. The FAS-DPD will reliably measure up to 50ppm FC. --paulr Quote Link to comment Share on other sites More sharing options...
quantumchromodynamics Posted August 1, 2009 Report Share Posted August 1, 2009 PaulR, I think that you may have accidentally posted your replies to the wrong post. Quote Link to comment Share on other sites More sharing options...
PaulR Posted August 1, 2009 Report Share Posted August 1, 2009 I am responding to this: I purchased a Taylor Test Kit K2005 (they didn't have a K2006) followed by this: This evening's readings of the pool water are: Free Chlorine=5 (the darkest reading) Total Chlorine=5 (the darkest reading) PH: 8.0 Acid Demand = 3 drops to 7.4 Alkalinity: 12 drops or 120ppm Calcium hardness: 45 drops x 10 for 450 CYA: 58 ppm The color-matching chlorine tests such as the DPD in the K-2005 behave a little erratically over FC5, in my experience, and I was trying to inject a note of caution because the phenol-red pH test definitely reads too high when FC gets higher than about 10. But in re-reading the posts I see that pH has been 8.0 pretty much all along, even at low FC, so "never mind." --paulr Quote Link to comment Share on other sites More sharing options...
Landene Posted November 23, 2009 Report Share Posted November 23, 2009 I think Muriatic will be better for this than dry acid, although handling the muriatic requires more caution.The chemical is dangerous..Keep a safety procedures by using it.. Regards Landene Surendettement Quote Link to comment Share on other sites More sharing options...
zooxpoork Posted November 27, 2009 Report Share Posted November 27, 2009 Hi Everyone I was wandering if anyone knew what standard the 5k Open Water swimming is....ie times, qualifying times etc.... I had a letter from British Swimming trying to tempt me? Tanks a Million Quote Link to comment Share on other sites More sharing options...
