ginclar Posted June 29, 2009 Report Share Posted June 29, 2009 Hi everyone I have a 2004 Sundace Optima - never a stich of trouble till last week. When pressing the 2 speed pump control button on the panel he blower comes on, press the blower, the 2 speed pump high comes on in high. Also when pressing the #2 pump that runs imtermittanly or not at all. Have tried powering off and on to no avail - the above happens whether using the main or side control panel. All else is normal (temp, lights, meu options etc) Any thoughts would be much appreciated -- thanks and have a good day - Glenn Quote Link to comment Share on other sites More sharing options...
tony Posted June 29, 2009 Report Share Posted June 29, 2009 Hi everyone I have a 2004 Sundace Optima - never a stich of trouble till last week. When pressing the 2 speed pump control button on the panel he blower comes on, press the blower, the 2 speed pump high comes on in high. Also when pressing the #2 pump that runs imtermittanly or not at all. Have tried powering off and on to no avail - the above happens whether using the main or side control panel. All else is normal (temp, lights, meu options etc) Any thoughts would be much appreciated -- thanks and have a good day - Glenn Could be the auxiliary control pad. Unplug from the control box. If the problem stops, thats the culprit. You can still operate from the main. Faily simple fix but you have to pull a new wire from the front of the spa to the back. Quote Link to comment Share on other sites More sharing options...
