Blower Has No Power
I have an in-ground pool and spa. The blower on the spa was functioning normally until power outage last fall. Now it has no power at all. Is there a fuse or something that I could check to see if a power suge may have blown it?
There generally is no reset button on blowers. You need to remove the wires and test for voltage to see if it getting power. It also could be the switch used to control the blower
