lbenn Posted October 27, 2006 Report Share Posted October 27, 2006 We just moved in to a house in Bonita Springs and it has a built in swimming pool with a fiberglass liner. Underneath the liner is a big bubble in the middle filling with water. How do we drain the water and is the fiberglass pool ruined? My husband is doing the work, but I say if he doesn't act soon, the water will continue to ruin the pool. Help! Anyone know what we can do?? Thanks! P.S. He tried using a pump to pump the water. Quote Link to comment Share on other sites More sharing options...
adwh.com Posted March 11, 2008 Report Share Posted March 11, 2008 We just moved in to a house in Bonita Springs and it has a built in swimming pool with a fiberglass liner. Underneath the liner is a big bubble in the middle filling with water. How do we drain the water and is the fiberglass pool ruined? My husband is doing the work, but I say if he doesn't act soon, the water will continue to ruin the pool. Help! Anyone know what we can do?? Thanks! P.S. He tried using a pump to pump the water. Quote Link to comment Share on other sites More sharing options...
don pool Posted March 12, 2008 Report Share Posted March 12, 2008 Was the pool already drained or did you drain it? Is there a leak in the plumbing or could you have a high water table. If you drained the pool on your own and there is no plumbing leak you have a high water table and you better start putting the water back in it at least half way full so your pool doesn't float or crack. The pool should have a gravel sump underneath it that attaches to a pipe somewhere in the concrete at the deep end of your pool. If you have one that's great because it will relieve some of the hydrostatic pressure under the pool. Quote Link to comment Share on other sites More sharing options...
