JeffT Posted March 24, 2009 Report Share Posted March 24, 2009 Hi all, Just wondering if there are any opinions on the goldline sense and dispense offerings. Specifically the one that interfaces with the aquarite pro for monitoring and adjusting the chlroine levels through the generator. Any opinions would be appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
AZMermaid Posted March 24, 2009 Report Share Posted March 24, 2009 Of course the Sense & Dispense is very new, and will likely have a lot of bugs to be worked out. If you are a homeowner buying for your personal use, I wouldn't suggest any pH and Orp control. These types of systems are usually for commercial pools with high and continuous bather loads. I'm betting there will be continuing calibration of the system required, and likely won't save you any time on pool maintenance for a small pool. Not to mention the C02, etc that will need monitoring as well. Quote Link to comment Share on other sites More sharing options...
