cloudy pool
Guest Michelle
Guest Michelle
Help, This morning I check my pool and all my chemical level were in the correct range but the water is still very cloudy, I added some shock and wait about three hours and tested it agan . My pool is 14,000 gallon 24 ft round. the reading I got the second time were as follows
TBr 10
FCI 10
ALK 40
PH 7.2
Thurday I tested the water and had o alk at all so I added 10LBS of baking soda.
The water is a light greenish blue and very cloudy, I can see the bottom at times but not always. Please HElp!
I started to see some algae forming on the bottom on my clear pool so I tested the chemicals and saw my PH was a little low so I put some PH up in it and it became milky cloudy right away. Should I just put some PH down in there and wait?
Thanks ,
Todd
