PennPal Posted October 26, 2008 Report Share Posted October 26, 2008 I have had 2 ozonators fail on my 2004 Sundance Marin. I'm wondering if I might have a problem with my control board. This spa runs on 220/240 volts. When I check the connection (at TB6) I have 120v on the black all the time. The same holds true for TB4. The white kicks in with the relay after a few minutes of operation which seems like normal operation. The first ozonator was the original Sundance and the other one was a aftermarket electronic one but still had the bulb. The second one is only about 8 months old the light will light if I unplug it for a few minutes when the relay is on and then plug it back in but it only stays lit for a few minutes even though I still have power at TB6. I never have any problems with the GFI or any overloads but we do have some power issues in the area (burn out a lot of lights and have to reset Sat boxes once in awhile). Any thoughts or suggestions are welcomed. Thanks. Barry Quote Link to comment Share on other sites More sharing options...
