rye67 Posted July 11, 2008 Report Share Posted July 11, 2008 I have a Waterway sand filter. The last few days I've noticed my pressure dropping as the pump runs (from 11 p.s.i to about 6 p.s.i). I've also noticed alot of air bubbles coming from the return into the pool. When the pump shuts off all of the water in the strainer basket disappers. As it disappears I hear a loud sucking sound. When I take the strainer lid off it sounds sort of like when you open a plastic bottle of soda. I'm sure I am sucking air and was wondering if anyone else has had similar problems. *Note* I do not see any air bubbles inside the strainer lid when the filter is running. HELP!!!! Quote Link to comment Share on other sites More sharing options...
ANG Posted July 11, 2008 Report Share Posted July 11, 2008 You have an air leak. Easiest way to find out where it is , is to let the pump pick up its prime and shut the pump off. Water will spit out where the leak is. Hopefully it will be in the pump basket o-ring which can be replaced. It couuld also be in a valve or the male adapter on the suction side of the pump. Quote Link to comment Share on other sites More sharing options...
rye67 Posted July 11, 2008 Author Report Share Posted July 11, 2008 Thank-You I will check! Quote Link to comment Share on other sites More sharing options...
