BamaCoast Posted April 19, 2008 Report Share Posted April 19, 2008 Should the sliding door on the filter compartment be up or down while using the hot tub or does it make a difference? I assume the door should be down when running the cleaning cycle? Advice would be appreciated. Quote Link to comment Share on other sites More sharing options...
spatech (the unreal one) Posted April 19, 2008 Report Share Posted April 19, 2008 Should the sliding door on the filter compartment be up or down while using the hot tub or does it make a difference? I assume the door should be down when running the cleaning cycle? Advice would be appreciated. 1) Does it matter? Not really IMO. Its there for skimming and I doubt you have much debris. 2) It should be in the up position unless the main pump(s) is on and then it gets sucked down until the pump(s) goes off at which time it rises back up. Quote Link to comment Share on other sites More sharing options...
BamaCoast Posted April 19, 2008 Author Report Share Posted April 19, 2008 Thanks for the info. Should the sliding door on the filter compartment be up or down while using the hot tub or does it make a difference? I assume the door should be down when running the cleaning cycle? Advice would be appreciated. 1) Does it matter? Not really IMO. Its there for skimming and I doubt you have much debris. 2) It should be in the up position unless the main pump(s) is on and then it gets sucked down until the pump(s) goes off at which time it rises back up. Quote Link to comment Share on other sites More sharing options...
