memery Posted February 25, 2008 Report Share Posted February 25, 2008 jacuzzi j345 purchase date june 05,since december 06 to feb 07 it has had 4 heaters replaced,has anyone had or heard of a similar problem,why is this happening,getting discorridged !!,need help badly Quote Link to comment Share on other sites More sharing options...
thestallion Posted February 25, 2008 Report Share Posted February 25, 2008 jacuzzi j345 purchase date june 05,since december 06 to feb 07 it has had 4 heaters replaced,has anyone had or heard of a similar problem,why is this happening,getting discorridged !!,need help badly That is odd but how consistent are you with your water care, do you balance you Ph/Alk weekly? Quote Link to comment Share on other sites More sharing options...
memery Posted February 25, 2008 Author Report Share Posted February 25, 2008 jacuzzi j345 purchase date june 05,since december 06 to feb 07 it has had 4 heaters replaced,has anyone had or heard of a similar problem,why is this happening,getting discorridged !!,need help badly That is odd but how consistent are you with your water care, do you balance you Ph/Alk weekly? had water tested day before last one failed,and most tests read good,usually need a little ph- but tests are generally good Quote Link to comment Share on other sites More sharing options...
thestallion Posted February 25, 2008 Report Share Posted February 25, 2008 jacuzzi j345 purchase date june 05,since december 06 to feb 07 it has had 4 heaters replaced,has anyone had or heard of a similar problem,why is this happening,getting discorridged !!,need help badly That is odd but how consistent are you with your water care, do you balance you Ph/Alk weekly? had water tested day before last one failed,and most tests read good,usually need a little ph- but tests are generally good Yes but how often between tests. It should be weekly like clock work. Quote Link to comment Share on other sites More sharing options...
memery Posted February 25, 2008 Author Report Share Posted February 25, 2008 jacuzzi j345 purchase date june 05,since december 06 to feb 07 it has had 4 heaters replaced,has anyone had or heard of a similar problem,why is this happening,getting discorridged !!,need help badly That is odd but how consistent are you with your water care, do you balance you Ph/Alk weekly? had water tested day before last one failed,and most tests read good,usually need a little ph- but tests are generally good Yes but how often between tests. It should be weekly like clock work. i do test weekly like clockwork Quote Link to comment Share on other sites More sharing options...
thestallion Posted February 25, 2008 Report Share Posted February 25, 2008 Very uncommon. Maybe its just a fluke. Most problems like this are from people who do not balance thier water. Quote Link to comment Share on other sites More sharing options...
avasicek Posted February 25, 2008 Report Share Posted February 25, 2008 My memory is a little fuzzy from back then, but I do remember a decrease in flow being attributed to the element not cooling enough (or close enough to spec for the element) and a handful of customers going through elements. Are you seeing any flow errors at all, or a physical drop in pressure from your circulating system? Filters are good, new, etc? Its been quite a few years now, so just tossing this out there. It may not be what you are experiencing. The heating systems were always pretty solid on the Jacuzzi I had access to. Its a very unusual problem you have noted here. Quote Link to comment Share on other sites More sharing options...
memery Posted February 25, 2008 Author Report Share Posted February 25, 2008 My memory is a little fuzzy from back then, but I do remember a decrease in flow being attributed to the element not cooling enough (or close enough to spec for the element) and a handful of customers going through elements. Are you seeing any flow errors at all, or a physical drop in pressure from your circulating system? Filters are good, new, etc? Its been quite a few years now, so just tossing this out there. It may not be what you are experiencing. The heating systems were always pretty solid on the Jacuzzi I had access to. Its a very unusual problem you have noted here. thanks for your input,i have had this suggested to me by another pool/spa dealer,that i have the limit switch tested,and to check/replace filter cartridge,how often do the cartridge need to be cleaned/replaced in this unit,in the manual it says periodicaly,whatever that means,i really am a newbie at this,and getting very discouridged,i will have the spa shut down and winterized,and test the limit sw thank you Quote Link to comment Share on other sites More sharing options...
