Showing results for tags 'low'.
I have a 2000 Sweetwater Palermo spa. The water temperature is 3 degrees lower than the digital readout on the display on my control panel. (the temperature from a thermometer of the water reads 97 degrees but the display reads 100). I have a new heater, new filter and recently changed the water. I've had this spa since 2000 and am very familiar with how it heats and this is really not normal for the spa. Any clues what the issue might be? Sensor, topside control panel, etc.? Thanks.
We just got a used 2008 Dimension one California jasper model hot tub. We are new to hot tubs. We ordered new filters and installed them. The tub heats up but we keep getting “Low flow error”. Not sure what is causing this to happen. Just want to enjoy my new spa and we have yet to make it in. Thanks to anyone who can help.
So the low speed jets that circulate the water and gets the water hot was working fine. Then I did test using the test trip to check chemical levels and it was high for ph so used spa down and got that to the ideal level also it was low on bromine it was a pink shade so just one less then the first ideal level so I thought I added the correct amount it said 4 teaspoons to every 200 gallon water and i think mine is 1200 gallons and I actually put in less then that maybe for like 600 gallons since it was close to the ideal level. I waited the 30 minutes I did a test again and it was at the high
The Story behind the tub. i purchased a balboa hot tub from a spa company in my city and this tub is a 1998. when i first set everything up they forgot to send me the pump so when i called them they couldnt find it and gave me a brand new ultra jet pump. when i wired everything up the lite leader board wasnt putting out the right voltage so i had to get it replaced. once i finally had everything said and done the problem im having is the following When i wired the pump up the diagram on the lite leader showed brn blu and blk going to pump as high low and common. and the wires that i have fo
