Ok so just finished working on it I used my amp clamp and wasn't getting any draw from the heater. I then tested the heater ad it seems to be good ! Next step I did was over ride the pressure sensor. I read that Iu must do this within 5 seconds of turning the power on. This worked. I got 16 amps on the amp clamp. And 240 volts. I checked for continuity on the pressure sensor and it indeed does work. So unadjusted it properly using the continuity meter and turning the pump on a few times. Here is the issue. The pimp only turns on about 9 seconds after turning power on and for some reason this is to long and won't turn the heater on. Is this making sense? I can get heater on if I manually over rode the switch within 5 seconds.
Thank you guys so much for your help so far. It's been such a blessing.
