I put jumper back on J11 and turned dip switch 10 to OFF for Heat w/Hi Pump. Also jumper wire removed. I did the 220V to 110V conversion when I installed the tub months ago, so I was pretty familiar with the reversal of the process to go back to 220V
We just took pump and heater off, looked for blockages, backflushed all piping. There were no blockages to prevent flow.
Put in test mode after refilling with our lake water (currently 36 degrees F) and sensos read:
On High pump: A 36, B 38 - 2 degree spread
On Low pump A 36,B 41 - 5 degree spread
Done with no filter in place, filter in place trips the LOW pump HL code.
Looks like on low I'm 1 degree spread off tripping the HL/DRY code. Not much room for error here, which is what I believe my issue is. Now.. How do I fix it after we have essentially started fresh here with drained tub, flushed electronics behaving as it should. As the tub heats up I expect I'll start running into the HL code on Low pump even with the filter off.
