I've asked before on another forum and never figured it out so figured I would try again on here. I have an Aqualink PDA system with a Pentair Variable speed pool pump and Pentair Laminars, 2 of them. The problem I have is I turn on my laminars and they work great. For about 30 minutes or so. Then they start to get lower and lower. They also start to sputter so I'm guessing they don't get enough flow. One seems to be worse than the other although both aren't great, but one ends up with a little sputtering but is still basically working while the other ends up a pathetic mess that doesn't resemble a laminar stream. The thing is, if I turn the pump off and back on, they perform great again for about one minute while its in prime and then they also work but they are much lower because it drops out of prime. Weird if its a flow issue. If I turn off the laminars and turn off the pump and then turn it back on again and then turn on the laminars, they work great for whatever amount of time before going to crap again. I'm at a loss with this. Its a Pentair 3hp VS pump BTW. It is set for basically top RPM when the laminars run and when blower is activated for the spa. Never notice an issue with the spa bubbles dropping out, but the blower does turn off after 30 minutes. Anyone have any ideas. its really starting to make me insane as I was about to start pulling apart the laminars to figure out what is wrong, but I realize they are only spitting when the flow starts to drop.
I also need to figure out how to angle these pentair laminars if anyone has any suggestions, As it is now, I can set them however I want, but once I drop them down in the hole, they basically just move to whatever position they want.
