Hi Fitz2380,
I have the same issue. Hoping you have had a breakthrough lol.
I have a brand new spa (400gallon), 2 pump system. Pump 1 is a 2 speed, pump 2 is off or on with a high speed or off. My pump 1 works great and has never failed. My pump 2 will work for a while and stop pumping or making noise after 30 minutes or so. (I’m not talking about the automatic timer that stops it). Pump 1 will still be running on high but 2 just goes silent. It still shows on the electric panel that it’s still on but clearly not. I can turn it off and on and it’s says so on the panel. No error codes. The panel has no clue that anything is amiss. After about an hour or 2 it will work normal again and then repeat. I have correct voltage coming to the hot tub. 220volt, 6 gauge (4 wires) from breaker to sub panel and to hot tub. The only thing I can come to a definitive answer is the pump is overheating. This hot tub is 4 days old and it’s great when it works. Luckily pump 1 runs half the jets and I can still use that side of the tub when pump 2 fails and the other half of the tub jets are nonexistent. it’s been nice to read all of your comments on this thread and it all makes 100 percent sense. This may be too late for you to see or even look at again but if you do respond and have an answer, I’d greatly appreciate anymore insight.
