We have been a bit busy and not been able to utilize the hot tub much since my original posts. However, last night we were in the hot tub and this is what I noticed.
Almost exactly 30 minutes after turning on Pump 1, the pump shut off. I could not turn the pump back on. When I check the panel, it shows the pump running and I can cycle the pump using the panel and the indication is that I am cycling between off/slow/high but the pump does not turn back on. After about 50 minutes, the pump must have still been in the on position and it started up again.
My wife and I recall the pump or pumps shutting off after about 30 minutes when we first got the hot tub, but we believe we just turned them back on. We always assumed there was a timeout feature for the pumps. However, we are not 100% sure of all this and don't recall if both pumps did this and if both pumps would be turned back on.
Since my last post, I did replace the filters so I do not feel it is a flow issue if that is what may cause the pump from shutting off. I do not get any error condition in maintenance log feature available from the panel.
Again I am trying to determine what might cause this issue or is this some normal feature of the hot tub.
