Hello Mike, the end caps are easy to locate on the www. If you are going to do the replacement of endcaps. Do replace both endcaps due to inner gasket fatigue becoming brittle from heat and chemicals. The price for the set will be over $200. The lifetime of a heater assembly is rated at around 4 years. I replaced the small endcaps only to have the large end failed a month later due to brittle gaskets. Backyardplus.com 805.541.9000
