I bought a new balboa vs series spa pack to replace my old balboa 52326. The vs runs a 2 wire 2 pin led light. What I would like to do is to be able to use my existing 3 wire led lights as well. Is this remotely possible
I’m not sure it was on it when I got it. It just sucks because if I buy relays and it doesn’t work, I buy heater with no change then i buy board. If it goes that way I’d been better to buy whole unit and heater lol. They’re not hot tubs their land boats😂
Both green ground and neutral. Showing 240 volts on heater.with the heat turned off I’m reading 32-34 on terminal 1 and 3. Unplugged the sensor harness everything shuts off with code sn1. And the picture isn’t clear bc I have my labels on my wires still. Also for the wiring diagram front cover was gone off unit when I got it. That’s also the clearest picture I can get of breaker with my iPhone 5 lol
Also on my terminals 1-6 all are reading around 125v except for number 1 it’s reading 30-40 which is where my other heater wires is. With the heater wires unhooked k3 high limit relay is engaged
