im glad i found this,just removed my very noisy pump and found ss shaft worn and plastic bearings worn too.
ive ordered one of the suggested replacements above,but also ordered 4mm ss rod and a 4mm drill, im fortunate enough to have a lathe so i will try drilling out the original and use the new shaft. i also found carbon fibre shafts too,if this works ok i might invest in a carbon fibre shaft. i have gone to 4 mm because the plastic bearings easily accommodated a 3.7mm drill in the most worn area. as far as i can tell the original shaft is 3mm where it isnt tapered with wear, will see what happens.thanks for all info above
