I have also a miami. After the first summer everthing seems fine, only some deformation of the liner around the upper white part of the liner. The A hole leak is very common, even Bestway writes that some water leakage is expected somewhere on the website.
The real sealing is the double return valve shown in the picture above. First you have the weak return valve in the liner->thenthe first hemispheric seal, this closes the existing leakage. Behind it, in the 90 degrees knee there is a small exit valve, after the 90 degrees knee is the second last barrier hemispheric seal before it goes to the main electric parts. So they are aware of the issue. If your egg leaks the water is coming from the exit valve means the first hemispheric seal is broken.
Actually after getting into all the (other) issues with lay z spas people should reconsider buying another brand. Their products are designed to fail and the spare part policy is creating a kind of “black market” with sometimes very high prices. Most of the time its better to buy a new whirlpool. Some DIY stores in Europe offer the whirlpool for 300€+. But its still pricy to buy every summer a new faulty product...
The 2021 lay z whirlpools have a new “egg”, anyone a idea of improvements for the issues?
