bendite
24 -
Gender
Oregon
bendite's Achievements
Bail it out. shop vac the remains, get a non scratch cleaner from a local spa retailer or online, then final clean with rubbing alcohol. Checking with the manufacturer always is a good idea. Some interior shells require special care.
Share your experience with adding chemicals to the water IE: walking or dumping. Some manufacturers recommend dissolving dry chemicals prior to adding to your spa. Has this made a difference to anyone. I have been adding "Alkalinity up" dry and dumping it rather than walking it over the surface. I think this is causing the PH to continually rise day after day. Any Comments? When I add PH down I always dissolve first and walk it over the surface. Works great that way. Bendite
I purchased a Marquis Envy about 6 months ago. My tub is running on 110/120. My electric bill went up about $7 a month. I expected about 5 times that much. I use it about 1/2 hour a day and I am very pleased with the low cost. I live in a cold climate as well.
6 month review. No problems with any part of the Hot tub. My electric bill went up about $7 a month using 110/120v Not kidding. This is a good sign of quality. I am happy with the size for 2 people. The jets have plenty power for me on the smaller pump available. Two times the breaker tripped due to tub use and a lot of kitchen appliances running at the same time, not sure if 220/240 would have made a difference. Ideally 220/240 would be best for cold climates so the tub will heat while the jets are on high. Great Tub for two people
Pre Filter For Filling Tub And Green Water
bendite replied to Nat's topic in Hot Tub Water Chemistry
I am on Well water with lots of sediment. I tried several pre filters and clogged them all with in 10 minutes. I can tell you even if you dont have sediment the pre filters will slow your fill time considerably. I would say 10 times longer. After all pre filter attempts failed I purchased a secondary main tub filter, filled the tub, let the tub filter catch all the sediment after a few cycles, then replaced the filter with my back up in a day or two and all as good for 3-4 months. If your problem isnt sediment and you dont mind a much longer fill time I would use the Micropure pre filter. See my post titled "pre filter" using the search button on top right of the page. I am on page 4 of search results -
here is a response from Taylor Technologies when I asked why their literature said test immediately but their customer service said let samples cool off. Dear Bendite, Thank you for your email, it was forwarded for my reply. Higher spa temperatures can affect test results. The current recommendation is to let spa water cool to an ambient temperature or at least under 90ºF before testing. If you take a 25 ml sample of the hot water and let it sit for about 30 seconds, which could still be considered immediate. It usually cools down enough to get an accurate test. Sincerely, Jarad Proctor Customer Service, Technical Support Taylor Technologies, Inc. 800-TEST KIT (837-8548) (F)410-771-4291
I contacted Taylor Technologies and they confirmed that before testing water samples you should let the sample Cool off first. Hot water does affect the reagents. I did not get a allowable temperature however. This does not mean lowering your spa temp, just the sample. Surprisingly Taylor test booklet suggest's testing the sample immediately, I am guessing this is a "pool" suggestion since the pool water is colder. Anyone know if room temperature would be OK?
I am contemplating buying a hot tub for my wife and myself. I have narrowed the choose to the Marquis Envy, Jacuzzi J210, Cal Spa VX 520R, Solana RX and Coast Spa Geneva. My biggest concerns are assuring comfort, getting good shoulder soaking and quick heat up time. From what I have read so far, neither of these units appears much different from each other. I wanted to ask you on your experience with the Marquis Envy regarding my concerns? Mike T Mike I suggest going 220/240 for faster heating times. 110/120 maintains the temp all right but I can tell in the winter it will cool quickly while using it. My wife and I have found the Envy to be a perfect 2 person spa. This is not a lounging tub, but you can still stretch out if you want to. You just wont get back support. I have good shoulder coverage. I am 5' 11" 200 lbs. The water level rises over the water filter housing when you get in, as it is designed to do. There are some upgrades for this model. I wouldn't upgrade to a 160GPM pump. The 120 GPM does just fine for me. I do wish I would have gotten the built in chemical cartridge upgrade feature but the frog is only a bit of a hassle. Bendite
Just received the MicroPure micron pre filter. It is trickling at .25 GPM. Thats right 1/4 GPM. At this rate my 250 gallon hot tub will be filled in about 16 hours. I suspect it will clog long before that, making this product a waste of money for filtering sediment. The MicroPure rep online suggested this pre filter for sediment. I hope PoolandSpa will refund my money. Bendite Poolandspa would not return my money for the pre filter I tried. Not surprised. Customer service these days is weak. Hope my experience saves someone else some money. Pre filters that attach to a garden hose just dont work. If you have a lot of sediment there are some serious house filters, but they cost a lot. Bendite
You two have just hi-jacked this topic for your personal chat. Seems to be a restraint issue at this forum
My local Marquis dealer quoted me the Envy for 5600 "SPECIAL PRICE" b'cos they have many in stock and wanted to "move them "...... BYE BYE Marquis !! Marquis is made very close to where I live so my lower cost probably is a result of shipping cost's. Also I had a no upgrade model. I think you can get them to lower the price. Have fun with the sales negotiation. bendite
1 month review Really enjoying the Marquis Envy. No problems! Perfect for my wife and I. The local Bend, Oregon Marquis dealer is Great. The spa temp comes pre set at 102 degrees. I found out later you can up it to 104. Oh Yeah!!! An upgrade to 160 GPM from 120 GPM pump is offered but my opinion would be, that it may be too much for this little tub. Keep in mind I have not experienced the upgrade so this is just speculation. bendite
Marquis Limited Series, Model 319s Tub - Comments/prices?
bendite replied to simmomi's topic in Portable Hot Tubs & Spas
The Stallion: I was not Knocking the Marquis brand. Just the length of time for 120v to heat up. SpaTech; I did think it would be cheaper for 240 so I guess I wont save any money. Other than quicker heating times a 240v will continue heating with the jets on high where as 120/110 will not. A good benefit in the Winter IMHO. Bendite -
MicroPure, a Canadian company makes 3 types of Pre filters. Their web site has a dealer locater option. I just ordered 2 Micropure micron pre filters from Pool&Spa and will give them a review on my next re-fill Please keep this topic on Pre filters. Bendite
