Most pool professionals could remove the drain cover and blow out the drain line using an air compressor. Just have to be careful, use a regulator to control exactly how much air pressure you are pushing the debris out with. If you do this and continue to have the same problem, as long as the pool isn't leaking, you just have a bad initial pool plumbing installation. You may try to upsize the pump to a greater horsepower if you feel you need the additional suction from the drains, however keep in mind when changing pump size, you have to match the flow rates to the filter and pipe size / number of pipes in your pool system. Hope this helps!
Trey
Backyard Pool & Spa
Gastonia, NC 28056
