Hi
I got error codes 172 & 186 on my Chlormatic III (2 port cell, threaded sensor) about 8 months ago, replaced the sensor and everything was fixed.
Now, only 8 months later I'm getting the same error codes again. The error was intermittent at first, but is now continuous.
I checked and the warranty on parts is only 3 months
I've checked the voltages on the back-board test points, and all the AC voltages are okay (just a little high), but of course cannot test the 120mV DC output since the error is preventing the cell from turning on.
I don't want to pay out another $200 after only 8 months if there is any chance that the fault could be with the front board, or anything else.
According to the fault code list here http://www.discountpoolwarehouse.com/html/clormaitc_3_codes.html
code 186 means "Heated temperature sensor reading too high. Near 5 Volts. Generates a 172 code flow sensor service condition."
(the actual pool temperature is around 92 degrees)
Running the diagnostics, with the sensor disconnected, I got test readings of 2.8, 74F and90F
Does anyone have the pinout for the sensor connector ?
I'd like to check the input from the sensor to see if it really is high, to help double-check whether the fault is with the sensor or the front board.
Checking voltages on the sensor connector randomly, I do get a lot of high (5.5v) readings, but am not yet sure if this could be because the voltage supply to the sensor is too high.
(I'm assuming the temperature sensor part is just a thermistor, but not clear on how the other sensors function)
Any help that saves me from wasting more $$$ would be greatly appreciated.
