AquaFinesseOne
AquaFinesseOne's Achievements
  1. AquaFinesse is not an enzyme; it is an all-natural product that not only removes the bio film that grows in tub it softens the feel of the water. By using AquaFinesse and breaking down the growth of bacteria you will be able to reduce your chlorine use by up to 80%. Most tubs use 1 teaspoon of dichlor a week and the tub stays in balance much longer. Not only do you reduce time you save in long run by not having to use all of the other products like anti foam, clarifiers and so on. It is much more than just an enzyme. Just so you know it is used now by 6 tub lines. The reason they use it is simple it does what it says it will do. It takes just one minute, one time per week, to keep your water crystal clear and silky soft. Its patented formula is all-natural, so it's better for the environment. Plus, AquaFinesse significantly reduces your need for harsh chemicals. You'll see the difference. And you'll feel the difference. It breaks down old calcium build up off plumbing and jets. It keeps the calcium off the heater elements also. The tub will stay cleaner inside. It is Kema, Montana State, and Lab Dervo tested. It is a NSF 60 product used in the food industry and it is used in the European medical industry also. The Spa Clean Puck is a spa purge that is use to clean out all of the biofilm and build up in the lines. There are no soaps in our product like some others. That is why the largest jetted tub company in Europe uses and recommends our product for all of their customers to use in their jetted tubs. FACT: Did you know that 99% of all bacteria live in the Biofilm, just 1% actually live in the water itself and it is only these so called 'free floating' bacteria that we are able to kill with traditional sanitizer's such as chlorine or bromine!! Chlorine and bromine in normal levels do nothing to biofilm.
