Hi all!
New to the forum I am!
I know that "DE migrating back into pool" has been covered here and elsewhere, many, many times but....
I have a 5 year old Hayward DE 24" DE filter, not the bump style, the I believe grid style. A few months ago I started to get DE in the bottom of the pool after a filter cycle. I pulled the elements down, found one with a cracked spout, where it fits into the manifold so given the age I decided to replace the entire set. Reassemble proper, including new O-Ring where filter manifold dumps into the return at base, add DE to Skimmer, let run and DE in Pool!
Next pop the cap on the multi-valve and not only was gasket worn, but a channel between ports was cracked. Ok, I'll play this game so $126.00 later, new 1-1/2" Hayward multi-port valve installed.
Filter cycle and oh crap...DE on bottom of the pool downstream of jets.
I've triple checked the Manifold for cracks, none, it appears perfect. I'm getting ready to install a Pentair Intelliflo VS to allow me to run at low speeds and save energy/$.
1. I don't have any idea where to look for the source of DE going back into the pool?
2. I'm hoping that running low GPM's with the new pump will solve the problem, wherever it is.
3. I guess if it doesn't I will need to replace the manifold in the filter as it may have a hairline that opens up or the whole darn
filter housing, manifold and all.
Any thoughts?
....and thanks!
The Crucian ---- St. Croix, Virgin Islands
