Yes it could be a clogged filter remove the filter and try running it. it could also be the pressure switch which is behind the heater and under the circuit board on my tub. my pressure switch screws in and has two wires from the board to it. i would imagine it has to be drained before doing this. another idea is bypassing the pressure switch if you still get the fl reading then its your filter a clog or circulation pump i am also new to this and only know this information from reading the forum. The only thing i have experienced is bypassing my pressure switch, which has not solved my problem so i am still learning lots. perhaps this wil help
