Dewdrops3 Posted May 7, 2013 Report Posted May 7, 2013 I have lost faith in our pool store staff. Our hydro pool swimspa has always been maintained using Bromine but not very well I must admit. It is very difficult to keep the Bromine levels up. We run the swimspa at 84 degrees in the summer, 104 degrees in the winter and in the spring and fall we usually run around 70 degrees. I completely drain and and refill two to three times a year. The swimspa gets full sun for a good 10hours a day for the spring and summer months. We have a hard top that we use if the outside temp is dropping significantly overnight or if there is rain in the forecast otherwise I use a solar blanket on the swimspa when it is not in use. Given the higher temperatures and sun exposure, should I switch over to BBB with with Bromine? I'm making an assumption that I need to maintain my chemical levels as per your guideines using the appropriate amount of chemicals for our 4100 gallon swimspa. I would appreciate your advice before I drain and start things up again this season. Be well. I haven't included and chem levels because I'll be starting from scratch. Quote
