theproteinfreak Posted June 16, 2009 Report Posted June 16, 2009 Hello all, Im new here and I have a couple questions regarding how to go about taking apart an above ground pool that is already set up, transporting it to my home, and setting it up. I would be greatful if you guys have any advice on the following. (POOL IS A 21 foot circle i think, im gussing thats side to side) 1) Instructions as to how to take this thing apart. 2) Transportation ( I think it will fit in a cube van but note 100% sure) 3) Initial setup 4) Some sort of maintenance guide. Thank you in advance, and i appreciate all the help you guys can give me. I'm sure i will be a active member for years to come with this pool. Quote
imnay Posted June 16, 2009 Report Posted June 16, 2009 You're asking for a lot in a forum response. May I suggest a simple Google search "how to install above ground pool"?? Another good Google suggestion is: "how to disassemble above ground pool". I just did those two searches and found a be-zillion hits leading to a LOT of good and step-by-step information. Hope this helps! Quote
