Hello all, Im new here and I have a couple questions regarding how to go about taking apart an above ground pool that is already set up, transporting it to my home, and setting it up.
I would be greatful if you guys have any advice on the following.
(POOL IS A 21 foot circle i think, im gussing thats side to side)
1) Instructions as to how to take this thing apart.
2) Transportation ( I think it will fit in a cube van but note 100% sure)
3) Initial setup
4) Some sort of maintenance guide.
Thank you in advance, and i appreciate all the help you guys can give me. I'm sure i will be a active member for years to come with this pool.
You're asking for a lot in a forum response.
May I suggest a simple Google search "how to install above ground pool"?? Another good Google suggestion is: "how to disassemble above ground pool".
I just did those two searches and found a be-zillion hits leading to a LOT of good and step-by-step information.
Hope this helps!
