Florida Badger Posted January 21, 2014 Report Share Posted January 21, 2014 Four years ago I got great advice here and ended up getting a pentair inteliflow variable speed pump. Great energy savings by running at 1000 rpm and am the envy of the hood. I'm now building a new house and pool and would like to know the current recommendations on pool pumps. I must say, I usually only run my pump on 2 speeds - slow and fast for cleaning. The question I have, would I be just as well served with a 2 speed pump. My new pool will be a pool spa combo and may have solar panels on the roof. I know very little about solar heating but assume I'd have to run a variable speed pump on a higher setting to pump through the roof panels. For how long does one run the water through the panels? If it's for a long time aren't I better off just getting a single speed pump? Any input would be appreciated. How many hp should my pump have for a 13K gallon pool. I know some pool guys have a one size fits all mentality. Thanks, Badger Quote Link to comment Share on other sites More sharing options...
brettnolan Posted January 21, 2014 Report Share Posted January 21, 2014 As noted in the other post, I would still go with the Intelliflo. You will be happier than with a 2 speed pump, and you will need two speeds, one for circulation another for spa jets. As you learned from the other pump, the energy savings are worth it. Quote Link to comment Share on other sites More sharing options...
