TubTime Posted September 4, 2007 Report Share Posted September 4, 2007 We are new spa owners and are confused on the chemicals. We are using the copper silver cartrige along with shocking the spa every three days, is bromine something seperate than the copper silver or do you use the two togeather, the water is very clear and the alk. and Ph are stable, we also have a 24 hr circ pump and an ozonator. Quote Link to comment Share on other sites More sharing options...
poollady Posted September 4, 2007 Report Share Posted September 4, 2007 We are new spa owners and are confused on the chemicals. We are using the copper silver cartrige along with shocking the spa every three days, is bromine something seperate than the copper silver or do you use the two togeather, the water is very clear and the alk. and Ph are stable, we also have a 24 hr circ pump and an ozonator. Stick witht he system you are using as long as it works for you. You don't need bromine too. Quote Link to comment Share on other sites More sharing options...
