calisoldier83 Posted December 23, 2017 Report Share Posted December 23, 2017 I'm on a fresh fill. Whenever I added boric acid in the past, I added it all at once. After that the water always gets cloudy. My tub calls for 18oz (around 2 cups worth). I also add 7oz of calcium, but not sure if I need to space that out as well? Any advice? Quote Link to comment Share on other sites More sharing options...
calisoldier83 Posted December 24, 2017 Author Report Share Posted December 24, 2017 To clarify, do I spread out the borate into multiple doses? Do you run the jets when you add it? I normally premix my boric acid in cold water then distribute across the spa all at once and run jets for 20 min. I have the same question for the calcium as well. Quote Link to comment Share on other sites More sharing options...
