Help identify spa / hot tub and its characteristics
Hello.
i moved to a new house recently where we have a spa/hot tab which does not work and i was kinda hoping to get to the bottom of it. and perhaps try and fix it.
first of all i wanted to know if the hot tub can heat water or is it only for cold water? this spa has no control panel of any kind. only 2 switches, which can be seen in the 4th picture on the top right corner. left switch turns on the pump which is connected to the filter and the 2nd switch is for the broken unit on the last picture that i have taken apart, it seems to me like air pressure for the bubbles perhaps? but im no expert.
heres the link for the pictures.  http://imgur.com/a/IkBk5
thanks in advance for any suggestions.
