How To Sanitize Removed Spa Jets From My Biguanide Spa
jimp
Hello All,
Newbie here. I bought a house which has a pool & spa sanitized by biguanide.
I want to make sure the spa is nice & sanitary so I took the jets out & want to sanitize them. I guess I can't use chlorox since I guess it's the same as chlorine, right? So, those of you who are biguanide users what do you recommend I use to sanitize the jets?
Thanks in advance.
Jim
If you removed the jets, you can disinfect them with anything so long as you rinse them thoroughly before and after disinfection. You just don't want chlorine and biguanide to mix, but rinsing the removed jets with water should work.
