UnderH20 Posted March 2, 2013 Report Share Posted March 2, 2013 I have most of a bottle of a "brominating concentrate" from a major spa company. It is ~15% sodium bromide, 82% dicholr, and 3% "other" ingredients. I really just want to do a simple 2-step bromine process on my tub. Is there a place for this stuff in that type of regime? I was thinking about just using it to establish my bromine bank on my next refil. I have a 350 gallon tub, which would normally require 1.75 oz. of pure sodium bromide to create a bank. Can I just add this at start up (1.75 oz / 0.15 = 11.66 oz) to establish my bromine bank? If so, should I add it over the course of a few days rather than all at once? I realize that it would be easier to just make the bromine bank with pure sodium bromine, but I am just trying to figure out how to use the stuff that I have. Thanks Quote Link to comment Share on other sites More sharing options...
chem geek Posted March 3, 2013 Report Share Posted March 3, 2013 Since it doesn't have that much sodium bromide in it, you'd have to use it over time to build up a bromide bank. Adding it all at once would be too high chlorine/bromine level. 11.66 ounces of 82% Dichlor in 350 gallons would be 113 ppm FC so way, way too high to do all at once. If you just use it as a disinfectant/oxidizer, then initially you'll have mostly a chlorine spa and eventually it will become more and more of a bromine spa. If that's not what you want, then you need to add a more pure sodium bromide product to start out. Quote Link to comment Share on other sites More sharing options...
UnderH20 Posted March 3, 2013 Author Report Share Posted March 3, 2013 Thanks chemgeek. That is what I suspected. I have to say that I do not really understand the intended use of this type of product. I find it to be confusing relative to a conventional two-step or three-step bromine program. Are there any advantages to using this type of product? Quote Link to comment Share on other sites More sharing options...
chem geek Posted March 5, 2013 Report Share Posted March 5, 2013 The product is designed to be used as the oxidizer in a bromine system when you've already established a bromide bank through other means, such as by adding a sodium bromide product. The small amount of sodium bromide in the brominating concentrate is to replenish the small amount of sodium bromide that may be lost from carry-out or outgassing (of bromine) or removed by filtration (some organic bromamines, if coagulated). Quote Link to comment Share on other sites More sharing options...
UnderH20 Posted March 6, 2013 Author Report Share Posted March 6, 2013 Thanks again. I did not realize that bromine was lost in any substantial way in a 2-step program. That helps clarify things then. Quote Link to comment Share on other sites More sharing options...
