gypsy Posted November 6, 2010 Report Share Posted November 6, 2010 We have a new to us Jacuzzi brand spa. When we were given the spa it needed a circulation pump and motor. We installed the motor and everything seemed to be working fine, except we have a very small leak. At first I thought it was coming from the drain valve. After removing the valve and plugging the 3/4" line it appears that the leak may be coming from the 2" x 2" x 3/4" Tee assembly. I was wondering if I should have to replace this Tee assembly, what type of cleaner, primer and glue should I use to make the new connections? One end will be rigid PVC pipe, and the other end is flexible PVC pipe. Thank you, Gypsy Quote Link to comment Share on other sites More sharing options...
PoolSpaGuy30 Posted November 6, 2010 Report Share Posted November 6, 2010 these should be available locally at any big box place here are the cements PVC Glue primer is available in the same brand as well Quote Link to comment Share on other sites More sharing options...
gypsy Posted November 6, 2010 Author Report Share Posted November 6, 2010 Thanks, for the link Weld-on makes over 20 products. There were a couple that said pool and spa in the name. I'm going to send them an e-mail. Thanks, Gypsy Quote Link to comment Share on other sites More sharing options...
