limulus Posted November 11, 2008 Report Share Posted November 11, 2008 I've been adjusting my chemistry once the tub was full, but I wonder if I should wait until it's up to temp. Quote Link to comment Share on other sites More sharing options...
Dust Posted November 11, 2008 Report Share Posted November 11, 2008 Myself, I do everything after its full, while its still cold. AFAIK, the only thing temp has to do with balancing (that we care about) is disipate chlorine... which actually won't affect how your balance your tub initially anyways. Even if thats not 100% correct, it can take hours for your tub to heat up. Do your really want 500 gallons of luke-warm water sitting there without sanitizers operating in a chemicaly effective environment? I sure don't. Quote Link to comment Share on other sites More sharing options...
tony Posted November 11, 2008 Report Share Posted November 11, 2008 I've been taught to wait until the temp was 85* to balance and that is what I've always done. Quote Link to comment Share on other sites More sharing options...
chem geek Posted November 12, 2008 Report Share Posted November 12, 2008 Most water chemistry tests are designed for room temperature -- in the 72-80F range -- but the only tests that are fairly sensitive to temperature are the CYA test and to some extent the pH test (pH changes with temperature, dropping by 0.14 when going from 80F to 104F). Generally speaking, you can let your water come closer to room temperature before performing the test, but this isn't critical. Quote Link to comment Share on other sites More sharing options...
limulus Posted November 12, 2008 Author Report Share Posted November 12, 2008 Most water chemistry tests are designed for room temperature -- in the 72-80F range -- but the only tests that are fairly sensitive to temperature are the CYA test and to some extent the pH test (pH changes with temperature, dropping by 0.14 when going from 80F to 104F). Generally speaking, you can let your water come closer to room temperature before performing the test, but this isn't critical. pH changing with temp is something I was pretty sure about, so thanks for confirming that. Quote Link to comment Share on other sites More sharing options...
