Hi All,
We have a spa that came with a home we purchased 2 months ago. The sticker on the tub under the cabinet shows "Sunset Spas" in Pace, FL. Model 1525 date of manufacture in '98.
The heater box is an easyPak EP2000A.
We first noticed the water was a lot hotter than the control was set to. We had it at 104, thermometer showed over 110 (it didn't go higher than that). So we set it to 98 and were good for a while, while we spend some time triaging the issue. Also, the control box (Gecko K-35) may be suspect as it misbehaves a lot when trying to set temps, now it is displaying in Celsius and no idea how that changed or how to change it back.
A few times in the past month the HL code would be displayed and I would shut the spa off, wait a bit, and turn it back on and at least it would function. I did change the filter as well to rule it out, the old one looked done.
So now what happens is the HL code is displayed all the time and the water doesn't heat. The heater light it lit on the easyPak, so what I did was run pump #1 on the higher setting (press it twice on the Gecko) and the pump runs for about 10 minutes or so and shuts off. I press the control twice and it starts back up. I can do this all day and eventually the water is up to heat and we can actually use the spa.
Would this indicate that the HL sensor (or switch) is bad and needs to be replaced, or more likely the whole heater assembly? I am tying to figure out where the HL sensor is so I can figure out what it is and replace it?
Thoughts and advice greatly appreciated.
-Eric
