Sundance Capri 1998
Have no control at all from the display panel (H267)
Panel reads: Temp:F100, Standard, Light is ON. No error message.
No other button functioning, Reset will not work.
When spa temp drops (?) spa turns on and heats to 100F then turns off. Normal maintenance cycles not working.
No visible damage from rodents. Connection on front and rear on the 850 panel is normal and panel light is on.
Note: Located in remote area, no service possible, nights are sub zero and getting colder.
Recently changed spa water, loosen pipe at the pump to bleed air out and it did work for a while with both jet and air-jet speed.
Need technical advise for problem or diagnose problem before buying expensive parts that can not be returned.
Is any one out there repair control panel?
Thank’ s
