I have a 2006 Great Lakes Sunlighter. The current issue is that when it tries to run in low speed/circulate mode, it runs for 1-2 seconds and then stops. It will try restarting on its own again about a minute later, and again stop after a second or 2. The display indicates no error code, although it does display "--" because it is not reading a temperature (normal for when the tub first "boots up"). I can press the jets button, and it will kick on high speed and run fine for several minutes, and the temperature will display fine. If I press the jets button again to drop to circulate mode, it will shut off shortly after.
It has a new display panel that I've just installed. The old one got moisture underneath it and was no longer legible, so I replaced it early this month. It was running when I shut it down for the summer, and this week is the first time I've tried running it since June.
I thought it might be a motor start cap issue, so I replaced that today, with no change.
Any thoughts on next steps?
